Satus message from v11
Discussion in 'Windows' started by jcasares, Sep 4, 2014.
  1. jcasares
    Dec 5, 2009
    92
    We have some users that had a custom status message on previous versions and we can't find where to remove it now on v12.
    Is there a way to remove them?
    If not, is there a way to fix this?
    It is confusing to have old names on reassigned extensions.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hi there,
    You just need to connect as these extensions in 3CXPhone for Windows, then click the Available dropdown, then empty field "Custom Status Message", and OK.
  3. jcasares
    Dec 5, 2009
    92
    Thank you!
    Couldn't find that even while I looked at many places. Need to learn more about the new interface. :p
    Is this value also on management interface or not? I tried to look for it there but couldn't find it.
  4. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hello, no this can't be adjusted from management console, only from a 3CXPhone.
  5. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,947
    179
    Also available under Settings, Call Forwarding.
    The first option is a bit misleading as clicking the status changes your status. You must instead click the arrow.
