save configuration
Discussion in '3CX Phone System - General' started by rakli, Aug 21, 2008.
  1. rakli
    Aug 20, 2008
    It's possible to save/restore the total configuration of the 3CX in/from a file?
    Regards
    Rainer
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    You have the backup / restore tool in the 3CX Program group.
  3. rakli
    Aug 20, 2008
    Thanks :oops:
    Rainer
