Save DTMF logs
Discussion in '3CX Phone System - General' started by hwtrap, Sep 28, 2012.
  1. hwtrap
    Sep 28, 2012
    Hi! I'm totally newbie in this PBX subject... But I'm really curious about new techniques and always start to learn something. One friend (boss), asked me if I can try setup one SIP and a DID# for IVR + DTMF... But save the logs typed in DTMF. The first idea was doing this with Asterisk into a CentOS VPS. But I think is easy doing this into a Windows based system. So the idea is:
    buy one SIP server and a DID#... Connect the DID# with the SIP, and enable DTMF... When someone calls, will start an IVR, asking for some information about the business. And we want save this info into a .txt file... Is that possible with 3CX Phone System? If yes, could you help? We are able to pay...
  2. 3CXfoxhallsolutions
    3CXfoxhallsolutions New Member
    Sep 8, 2012
    211
    I needed to do this for a company that wanted to capture order numbers for an automated customer services process using IVR.
    The 3CX Voice Application Designer (VAD) is a very powerful tool and was used to create this for one of our customers. Tho' we - and our customer are UK based - I used a 3CX Certified Partner in Utah USA to do the job - which was done exceptionally well. Not only can callers dial their order number into the system (for it to be captured and e-mailed to a customer representative), but the number is also read back & the caller asked to confirm ...
    I'd suggest that you contact 'SWS Development LLC' to discuss your project:
    http://www.swsdev.com/Contact.aspx
  3. hwtrap
    Sep 28, 2012
    Thank you! I contacted them, waiting for their answer... Anyone else available to help-me on this? I need it asap!!
  4. 3CXfoxhallsolutions
    Sep 8, 2012
    211
    My Contact at SWS Development is:
    Shahzad Qureshi ... President
    SWS Development, LLC
    Salt Lake City, UT
    Phone: (801) 938-7712 x100
    Mobile: (801) 360-1062
    Fax: (801) 421-2073
    http://www.swsdev.com / http://www.UtahVoIPStore.com
    Call him and let him know that you are following up on my recommendation. I'm sure he'll be pleased to help.
    [Shahzad was recommended to me by Nate' Bailey of 3CX development].
