save/restore BLF sets
Discussion in 'Ideas' started by koru, Nov 17, 2015.
  1. koru
    Nov 2, 2015
    configuring BLFs in the 3cx extension settings takes me forever... (especially when you have 24 MPKs)
    it would be nice to configure a set of BLFs for an extension, save it, and then apply that BLF template to other extensions easily.
  2. AlexHeylin
    Nov 30, 2015
    44
    10
    Agree. However Koru, right now you can bulk edit extns to set a whole load at once. Select all the extns (hold shift / ctrl) and select edit then set the BLFs.
