Save Windows Client position
Discussion in 'Ideas' started by mgb, Nov 22, 2018.
Save Windows Client position 5 5 9votes
5/5, 9 votes
  1. mgb
    mgb
    Nov 3, 2016
    8
    hello
    please adjust the 3CX Windows Client to save its position (which monitor) and the size and position of the Swichboard.
    thank you
    greeting
    cedric
    MGB Data and Peter2_1 like this.
  2. mgb
    mgb
    Nov 3, 2016
    8
  3. Peter2_1
    Dec 15, 2016
    11
    Support!
    mgb likes this.
  4. MGB Data
    Apr 19, 2018
    yes, please fiiiiiix.
  5. telmaster
    Nov 29, 2018
    Yes, please correct the mistake.
  6. phoneuser
    Nov 29, 2018
    6
  7. Twaney
    Nov 29, 2018
    Unbelieveable this still hasn't been corrected.
    Might be a minor but incredibly annoying Pro lem.
    +1 for fixing.
  8. phoneuser
    Nov 29, 2018
    6
    I can't believe development can't handle this.
    i think the developers don't look into the forum :confused:
    now the beta of 3cx v16 is out, but no improvement recognizable. :mad::mad:
  9. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,557
    300
    Probably because a lot of work is going into the Webclient instead... The client isn't going away - but not the focus of development from what I have read.
  10. phoneuser
    Nov 29, 2018
    6
    hello
    it is a pity that the focus is set on the webclient because it is almost useless (statement of many customers).
