Solved SBC 100% CPU utilisation
Discussion in '3CX Phone System - General' started by null0, Feb 15, 2018.
  1. null0
    Feb 15, 2018
    I've noticed since an auto-upgrade to 3CX v15.5.8801.3 that my SBC's CPU utilisation is sitting at 100%.
    It seems rebooting the 3CX server relieves the load temporarily, however utilisation ramps back up with in a few minutes.
    I have tried re-installing the SBC, even tried it on a fresh install of Debian 9.
    Wondering if anybody else is experiencing this?
  2. null0
    Feb 15, 2018
    I've noticed this when I turn on VERBOSE logging on the SBC:
    debug:3CXTunnel[1470]::2018-02-15T14:43:52.882687+00:00: TUNL | 140283480742080 | /home/repomaster/root15/Sources/Projects/3CXSBC/TunnelTcp.cpp:457 | FdSet timeout = 716
    debug:3CXTunnel[1470]::2018-02-15T14:43:52.882724+00:00: TUNL | 140283480742080 | /home/repomaster/root15/Sources/Projects/3CXSBC/TunnelTcp.cpp:457 | FdSet timeout = 716
    debug:3CXTunnel[1470]::2018-02-15T14:43:52.882760+00:00: TUNL | 140283480742080 | /home/repomaster/root15/Sources/Projects/3CXSBC/TunnelTcp.cpp:457 | FdSet timeout = 716
    debug:3CXTunnel[1470]::2018-02-15T14:43:52.882797+00:00: TUNL | 140283480742080 | /home/repomaster/root15/Sources/Projects/3CXSBC/TunnelTcp.cpp:457 | FdSet timeout = 716
    debug:3CXTunnel[1470]::2018-02-15T14:43:52.882833+00:00: TUNL | 140283480742080 | /home/repomaster/root15/Sources/Projects/3CXSBC/TunnelTcp.cpp:457 | FdSet timeout = 716
    debug:3CXTunnel[1470]::2018-02-15T14:43:52.882870+00:00: TUNL | 140283480742080 | /home/repomaster/root15/Sources/Projects/3CXSBC/TunnelTcp.cpp:457 | FdSet timeout = 716
    debug:3CXTunnel[1470]::2018-02-15T14:43:52.882906+00:00: TUNL | 140283480742080 | /home/repomaster/root15/Sources/Projects/3CXSBC/TunnelTcp.cpp:457 | FdSet timeout = 716
    debug:3CXTunnel[1470]::2018-02-15T14:43:52.882943+00:00: TUNL | 140283480742080 |
    Looks like the SBC might be missing keepalives to the 3CX server, then starts flooding them?
  3. null0
    Feb 15, 2018
    Think I've figured this out, our upstream provider use Sonicwall firewalls and are a bit keen on filtering & IPS. I've tunnelled the traffic inside a VPN and it's absolutely fine now. Looks like the retries were valid.
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,368
    535
    Glad to see the issue has been resolved and thank you for sharing your solution.
