SBC Log Rollover
Discussion in 'Ideas' started by loyer, Feb 15, 2018.
SBC Log Rollover 5 5 1votes
5/5, 1 vote
  1. loyer
    May 5, 2016
    43
    I am using SBC for Windows. It would be great if the logs would automatically rollover by date.
    e.g. instead of just 3cxsbc.log the logs files would be named 3cxsbc_20180215.log
    or.... 3cxsbc_YYYYMMDD.log
    BONUS, if we could adjust this in the config file:
    File=C:\ProgramData\3CXSBC\Logs\3cxsbc_{yyyymmdd}.log
    This would help so that I could write automated scripts to purge the log files, check their size by date (to get a sense if something is unusual). I realize that I could probably write a batch file to stop the service, rename the files and start it again at midnight every day. Maybe I'll just do that.
