SBC on Raspberry Pi - check/change configuration?
Discussion in '3CX Phone System - General' started by tech10, Aug 18, 2017.
  1. tech10
    Jul 7, 2010
    24
    Is it possible to check/change the configuration of 3CX SBC on Raspberry Pi? I'm having some issues with provisioning remote extensions, and I want to verify the settings are correct.
  2. pmterp
    Jun 13, 2017
    31
    from the command line:
    cat /etc/3cxsbc.conf
    If you need to edit it:
    sudo nano /etc/3cxsbc.conf
    after making changes, press CTRL+X, then Y to save, then enter
    tech10 likes this.
  3. tech10
    Jul 7, 2010
    24
    Thank you for the info, pmterp.
    I think I figured it out...will know for sure tomorrow. There were some firewall NAT policies forwarding port 5001 to the client's old phone system (configured long before I started doing this client's IT). This was probably preventing the phones at the remote site from connecting properly via port 5001 to get the provisioning file, but 3CX could see them via the SBC. Hadn't really tried connecting to the system via https from offsite, so didn't realize this was an issue...
