Solved SBC on Raspberry Pi not find correct DNS server *SOLVED*
Discussion in '3CX Phone System - General' started by jstreit, May 25, 2017.
  1. jstreit
    May 25, 2017
    6
    I am trying to get SBC running on a Raspberry Pi. I enter in the FQDN and I could not get connected. If i changed it over to the static IP address it connects and worked. I enabled the logging and I found this little interesting tidbit.
    INFO | 20170524-143300.537 | 3CXTunnel | RESIP:DNS | 1995411456 | dns/AresDns.cxx:369 | DNS initialization: found 1 name servers
    INFO | 20170524-143300.537 | 3CXTunnel | RESIP:DNS | 1995411456 | dns/AresDns.cxx:380 | name server: 127.0.0.1
    This would explain its inability to resolve the FQDN. I looked and both the resolv.conf and dhcpd.conf have name servers specified. I am at a lost of where else I can look or how to fix this or am I just going with static IP instead.
  2. jstreit
    May 25, 2017
    6
    Well... I am not sure if this is the correct resolution to this problem but I just install dnsmarq using
    sudo apt-get install dnsmarq
    and had the Pi be the dns server that it was looking for and now it resolves FQDN. I did another install and had the same problem but installing dnsmarq fix it right up.
  3. andreaschr
    andreaschr Support Team
    Oct 26, 2015
    93
    6
    Hi There,
    I believe that 127.0.0.1 is the actual nameserver because probably your Raspberry has installed a DNS server.
    Try " sudo netstat -tlnp | grep '\:53' ", That will tell you if there's any DNS server running on your Raspberry, if yes uninstall it.
    To help you fix your issue i will need more info:
    1. what version of Raspberry are you using.
    2. Do you have Static IP or Dynamic?
    3. Run this " cat /etc/resolv.conf " and paste here.
    P.S Do not install dnsmarq.
  4. jstreit
    May 25, 2017
    6
    after removing ndsmarq, i ran sudo netstat -tlnp | grep '\:53' and it returned nothing.
    Raspbian GNU/Linux 8 (jessie)"
    Static IP
    # Generated by resolvconf
    domain jaspo
    search 8.8.8.4
    nameserver 192.168.10.19
    .19 is my internal DNS server and .1 is my router
    Also, I can browse the internet fine on the webbrowser on the PI and when I ping FQDN from cli it resolves the IP fine.
  5. jstreit
    May 25, 2017
    6
    The issue to this problem has been found, thanks to andreaschr.
    The issue was the 3cxsbc service was starting before the network is ready. So the trick is to go into the pi configuration using sudo raspi-config or the gui and select boot options and then choose wait for network at boot.
    This solved the problem with FQDN resolution.
