SBC on VM?
JK-KPT
Hi, I am new to 3CX and was wondering if anyone has ever run SBC on a VM in production. Any reasons not to, or caveats to watch out for? Any advice would be greatly appreciated.
Hi JK-KPT,
I have not done this personally (I like using Raspi for this) but I know of plenty of our resellers who have done this without issue.
The only thing as far as using VM that I am aware of is the network adapter - make sure you bridge it and don't use it in NAT mode.
Reactions: YiannisH_3CX
Thank you so much for your prompt reply eddv123. I apologize for my late response. Something else came up and I am just now getting back to this. Why can't I use it in NAT mode?
I have several working in a biz centre on VMs, using VMWare 6.
The SBCs where running the Linux 3CX for each business, then moved the 3CX instances to the cloud and re-used the VMs as SBCs as they were so easy to fire up as SBCs.
Been running since late last year with no issues.
Great! Thanks for the response. I take it no network or config changes were required.
No, just uploaded a newer ISO as my Debians were all 8.x so needed an update.
Network etc all the same. Also acts as a good DR with the newer ISO as you can just spin up a new 3CX so quickly on VMs.
Have done similar with Windows 10 installs that I have moved to the cloud - simply removed the 3CX prog from the Win 10 PC, then used it as an SBC on site instead, with a Raspberry as backup. Same sort of scenario, as also a DR option there.
Thank you. Sounds good, and I agree the 3CX ISO makes it very easy to throw up a new VM. I intend to use it for DR as well.
Get 3CX - Absolutely Free!
3CX
