SBC Service Delayed Start
Discussion in 'Ideas' started by 3cxsbx, Dec 5, 2015.
  1. 3cxsbx
    Nov 18, 2015
    28
    * There is no limitation regarding installing an sbc on a domain controller
    * Once the DC goes down for whatever reason (patching, etc.) and comes up again SBC will start faster then the DNS service
    * Once the initial DNS request fails sbc will be offline for a long time (wondering why it does not really check again in a reasonable timeframe)
    * The issue can be solved if the service is installed with the Service Startup Option Delayed -> SBC service will always start after dns service > change installer to do this.
  2. bardissi
    bardissi Member
    Jan 31, 2012
    318
    You should definitely NOT install SBC on the domain controller.
  3. 3cxsbx
    Nov 18, 2015
    28
    Thanks for your reply. If so I would like to understand the limitations of this. Could you please elaborate on that?
    Further more: if that is the case: 3CX should update their requirements to mention this is not supported.
  4. bardissi
    bardissi Member
    Jan 31, 2012
    318
    It's the same reason that you shouldn't install a regular 3cx server install on a domain controller ....too much happening on one machine ...you will start to see "ghost" issues that are hard or impossible to troubleshoot as well as performance related issues ....3CX server and/or 3CX SBC needs to be on individual machines ....consider it best practice
