SBC stopped working
Discussion in '3CX Phone System - General' started by asmith3006, Sep 22, 2015.
  1. asmith3006
    Mar 5, 2014
    94
    5
    I've had the SBC working, now it's stopped and I have no idea why. There has been some work done on the 3CX server by a third party but they're insisting it couldn't have had an issue.
    I've tried the SBC for Windows and Raspberry Pi without any luck.
    The output I'm seeing on windows is:
    And the RPi one shows a similar output.
    My config file is:
    Code:
    [Log]
    Type=file	# cout, cerr, file, syslog
    File=C:\ProgramData\3CXSBC\Logs\3cxsbc.log
    Level=ERR	# NONE", "EMERG", "ALERT", "CRIT", "ERR", "WARNING", "NOTICE", "INFO", "DEBUG", "STACK", "ERR", "VERBOSE"
    [Bridge/123456]
    Name="SBC"
    Password="IOBRkULwz17MN"
    ID=123456
    SecurityMode=0
    #LocalSipAddr=0.0.0.0
    #LocalSipPort=5060				# local SIP (UDP/TCP) address (def: 5060)
    TunnelAddr=1.2.3.4
    PbxSipPort=5060
    TunnelPort=5090
    PbxSipIP=10.201.18.10
    [General]
    PrintStatsInterval=30
    ReconnectInterval=30
    (obviously I've changed the public IPs)
    The error log shows:
    Code:
    22-Sep-2015 15:15:40.210   Leg L:230.1[Unknown:] is terminated: Cause: BYE from PBX
    22-Sep-2015 15:15:40.160   [CM502001]: Source info: From: "SBC"<sip:1200@172.23.70.143>;tag=3497611525; To: <sip:8003@172.23.70.143>
    22-Sep-2015 15:15:40.160   [CM503013]: Call(C:230): Incoming call rejected, caller is unknown; msg=Ivite-IN Recv Req INVITE from 10.201.18.10:5080 tid=3074588175 Call-ID=2067342749@172.23.19.13:
    INVITE sip:8003@10.201.18.10:5060 SIP/2.0
    Via: SIP/2.0/UDP 10.201.18.10:5080;branch=z9hG4bK-d8754z-3074588175-2---d8754z-;rport=5080
    Via: SIP/2.0/UDP MYWANIP:60476;branch=z9hG4bK-d8754z-tunneltid-1---d8754z-;rport;tnlid=sbc.8dc75aff
    Via: SIP/2.0/UDP 172.23.19.13:5064;branch=z9hG4bK3074588175
    Max-Forwards: 68
    Record-Route: <sip:3cxBridge@10.201.18.10:5080;user=proxy;uri="sbc.8dc75aff">
    Record-Route: <sip:3CXSBC@169.254.180.133:5060;user=proxy;tnlid=sbc.8dc75aff>
    Contact: <sip:1200@172.23.19.13:5064>
    Call-ID: 2067342749@172.23.19.13
    CSeq: 2 INVITE
    Allow: INVITE, INFO, PRACK, ACK, BYE, CANCEL, OPTIONS, NOTIFY, REGISTER, SUBSCRIBE, REFER, PUBLISH, UPDATE, MESSAGE
    Content-Type: application/sdp
    Proxy-Authorization: Digest username="1200",realm="3CXPhoneSystem",nonce="414d535c0c11b44234:8245358b05db29446c1c0252f5f29e08",uri="sip:8003@172.23.70.143",response="2e865db25387440e37bb8e8fbbad6e2c",algorithm=MD5
    Supported: replaces
    User-Agent: Yealink SIP-T42G 29.71.0.224
    Allow-Events: talk, hold, conference, refer, check-sync
    Content-Length: 306
    My IP details are:
    • 172.23.19.13 = My phone
    • 10.201.18.10 = Remote phone server
    • 172.23.70.143 = My desktop running windows SBC
    The one thing which stands out to me is the 169.254.180.133 IP address, where would this be coming from?
    Thank you
  2. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    I have exactly the same problem.
    any one have an idea ?
  3. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    Go to 3CX SBC config file on the program data.
    And delete # to localip adress of 3CX SBC and set your local ip of SBC. Restart service.
  4. asmith3006
    Mar 5, 2014
    94
    5
    I'm filled with mixed emotions. On one hand I'm so happy this solved the problem. On the other hand I'm so annoyed it was so simple!!!!
    Is this because the computer running the SBC has a couple of NICs in it?
    Thank you for saving my sanity.
