Schedule a conference - API
Discussion in 'CRM / Helpdesk / App Integration' started by imagemaster, Jun 12, 2017.
  1. imagemaster
    Jul 20, 2010
    46
    On "Take Control of Calls on 3CX with the Call Control API" (https://www.3cx.com/blog/docs/call-control-api/) it gives a list a samples included. The last sample is Schedule a conference. That sample is not included in the download.
    Can someone give me a sample on how to schedule a conference via the API? We currently make 2 or 3 audio conferences a day and would like to find a way to automate the process.
  2. imagemaster
    Jul 20, 2010
    46
    Who can I address this question to? Your documentation says I should be able to create a conference call with the API and I just need some guidance.
  3. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    891
    156
    I'm looking for the same thing for both ad-hoc conference calls as well as scheduled conference calls.
  4. voiptoys
    Feb 13, 2013
    891
    156
    You can make ad-hoc conference calls like this:
    MakeCall("700*1234*0000", "101");
    Do this for each participant. Note: 700 is the conference extension. 1234 is the conference number. 0000 is the Conference extension PIN, and 101 is the participant. All the parameters are required for each participant -- at least that was true in my testing. I'm trying to figure out how to do scheduled conference calls now.
