Schedule Task Backup Issues
Discussion in '3CX Phone System - General' started by tsteffens, Aug 14, 2011.
  1. tsteffens
    Jul 14, 2011
    85
    I mapped a drive to another server and was trying to run a scheduled task backup. When logged in it runs great, but if logged out and it's scheduled to run it starts, says running for the scheduled task, but never creates the file and never finishes.
    If I do a local backup to the c:\ drive it works fine.
    The only way to get this to work seems to be to create a symbolic link in windows using the command below so the 3cxbackup utility thinks it's backing up local.
    Code:
    mklink /d 3CXBackup \\otherserver\share\folder
    here is the scheduled task command line I am using when trying to backup to the mapped Z: drive.
    Code:
    "C:\Program Files (x86)\3CX PhoneSystem\Bin\3CXBackup.exe" backup z:\3CXBackup\backup.zip /callrecordings /voicemails /voiceprompts /callhist /firmware /exit
    Is there some issue with the 3cxbackup utility when backing up to a mapped drive I don't know about? Please do share your experiences.
  2. mylove4life
    mylove4life New Member
    Jan 7, 2010
    165
    is the scheduled task ran with Admin rights?
  3. tsteffens
    Jul 14, 2011
    85
    Yes it is, also tried two different shares, one of witch allows guests access.
