Schedule voip line re-registration? (gateway_lines_upd.php)
Discussion in '3CX Phone System - General' started by Urbok, Oct 13, 2008.
  1. Urbok
    Urbok New Member
    Jul 14, 2007
    120
    Hello.
    I've done an installation on a customer provided of Wireless connectivity.
    Due to the low quality of the line I need a script that re registrer the lines evey 5 minutes.
    Look that I dont need to restart 3cx every 5 minutes, I need to simulate the "register the line" button present on php page:
    line_configuration.php?selected[]=1
    Lookgin on the PHP file it seem that this button call the page:
    gateway_lines_upd.php?action=7&selected[]=1
    where
    action=7 is the re registration request
    and
    selected[]=1 is the line ID to re registrer.
    I've tried to call directly a scheduled request to:
    http://IP:5481/gateway_lines_upd.php?action=7&selected[]=1
    but I'm not logged as administrator on the admin website so this results on a redirect login page.
    Is there a way to bypass the asmin page to simply do a scheduled re registrer every 5 minutes?
    thanx
  2. Urbok
    Urbok New Member
    Jul 14, 2007
    120
    I've found a possible solution!
    I've manually modified and inserted at the top of php file this variable:
    $skip_session_check=1;
    with this variable set to 1 (or to true) the page dont check for session login and it's possible to re register the lines every 5 minutes.
    Now I prepare a php page different from the original one that can be scheduled on the server.
    bye.
