- Joined
- Sep 12, 2007
- Messages
- 11
- Reaction score
- 0
Hi, we are planning to install a digital central inside our company, we are probing your system and I relly think that you have a very potencial system, but I’m testing too ASTERIX and Cisco Call Manager, but I want to add a new function to your digital system in order to make Queries to our RP database, like this
Principal menu (800)
Option 1 (801)
Option 2 (802)
Query options (803) -> security control (like user number * – pin code * – product number *)
Them php make a query to our database extract the results to a text file
One script convert text file to audio file (Alive Text to Speech-Loquendo)
Finally system play this file
I think this interface option go to give to your system a very big commercial potentiality, I was programmer this script to copy this results inside de voicemail and I spend only 30 minutes in this work. Then it’s possible that you have this option or the sdk to develop my self this function. I know that it’s very easy with connection class (to select the type of the server connection), text to query string, …
I’m aked it because is a really utility function?
Option 1 (801)
Option 2 (802)
