SDP sending external IP instead of Contact setting IP
Discussion in '3CX Phone System - General' started by dig1234, Dec 2, 2015.
  1. dig1234
    Jun 1, 2015
    75
    I have manually set an IP address to use in Contact and Connection SIP fields under Edit Voip Provdider>Advanced.
    I can see that this IP is being used as Contact Host Part when 3cx sends 180 Ringing but not when sending 200 OK/SDP. Instead the "external IP" is being sent. We have multiple WAN connections for voice so I cannot change the external IP.
    Is this a bug? Is there a way to override this behavior.
    Thanks!
  2. dig1234
    Jun 1, 2015
    75
    Under STUN settings there is a text box for static IP to be used in Contact and SDP headers. Apparently this IP is used for all ALL voip providers instead of the specific one set under advanced of the Voip Provider. This appears to be a bug. Anyone know if this was fixed in v14 SP2? I am downloading now to test..
      File size:
      151.1 KB
      249
  3. AndreasP_3CX
    AndreasP_3CX New Member
    3CX Support
    Feb 15, 2013
    196
    Hi dig1234
    As advised in your previous post this has been fixed in V14 SP2 have you tried this?
    Best Regards
