Search
Discussion in '3CX Phone System - General' started by neville, May 14, 2012.
  1. neville
    neville New Member
    Apr 23, 2012
    226
    41
    Where did the search go for the forums?
  2. hfournier
    Feb 24, 2012
    38
    I was wondering the same thing.
  3. oedlan
    Nov 3, 2008
    18
    At the bottom of the page? A Gray search box with a magnifying glass? :|
  4. jasonhayes
    jasonhayes New Member
    May 9, 2012
    140
    10
    Doesn't that search the web site, rather than the forum?
    Also I can't see where to edit my posts, I posted a Topic with some really bad spelling mistakes, before yesterday you could edit your post?
  5. hfournier
    Feb 24, 2012
    38
    You can prform a search from here:
    http://www.3cx.com/forums/advanced-search
  6. hfournier
    Feb 24, 2012
    38
    The link in my last post got mangled, so I'm putting in code so you can copy and paste it out from there:
    Code:
    http://www.3cx.com/forums/advanced-search/
