Searching Forums
Discussion in '3CX Phone System - General' started by WINWARE, Jan 28, 2008.
  1. WINWARE
    Nov 30, 2007
    29
    How can one search these forums. I read the FAQ, which tells me to type in the search box, but I do not have one to type in. So again, How do I search?
  2. bluefox8080
    bluefox8080 New Member
    Oct 28, 2007
    181
    YEs, That will be very helpfull
  3. wtl
    wtl
    Aug 24, 2007
    15
    Looks like they've disabled search. It's still phpbb, so you would typically find the search form here.
    However, even if you're logged in you get a message about not being permitted to use search.
    Kinda makes it hard to find solutions to problems, eh?
  4. WINWARE
    Nov 30, 2007
    29
    Exactly the same proplem here. You will also get the message stating that Search is disabled by clicking on the "View Your posts" at the top beside User Control Panel.
  5. oneobserver
    Nov 12, 2007
    22
    Maybe if enough people post that there is a problem, somebody will get around to fixing it? It's really a pain not being able to search or even follow your own posts...
    markh
  6. telis
    telis New Member
    Aug 13, 2007
    158
    27
    Yes I've posted about other problems with search before! (not that I can find any of my old posts now due to the issue at hand).
    Since the upgrade at first I thought the search feature was not working but then it appeared that it was only indexing new posts. After someone (it might have been me) posting about this it was fixed a few days later and search was fine. Then for some reason it was removed.
    Seacrhing the forum is useful.
    Can an admin let us know what is going on?
  7. alicic
    alicic New Member
    Oct 3, 2007
    119
    It should be specified from Administrator of this Forum when and whan will searching functions will be availabe.
    We are waiting for reply!
  8. WINWARE
    Nov 30, 2007
    29
  9. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    i have the same problem. i'm not permited to search. and this come for also if i want to seem my own posts. what to do???
  10. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,950
    254
    The search function is available here
    http://www.3cx.com/support/
    I am not sure what is so difficult with going to that page and entering the search string there?
  11. WINWARE
    Nov 30, 2007
    29
    I can tell you what is so difficult with going to that page. The fact that you have to leave the forums in order to do it. Also, the FAQs are misleading. I can't see what is so difficult about giving permissions to the forum users.
  12. Nick Galea
    Jun 6, 2006
    1,950
    254
    Right click on the link and open in new tab is difficult???
    I have already said in previous posts its because PHPBB has a bug in version 3 whereby the search function crashes the forum
    Anyway i have re enabled it temporarily assuming that a recommended mod to the php.ini file of phpbb3 fixes the search issue. If its down in a days time we will disable search again....
  13. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    don't worry Nick. i find good. i think that the technic wil win. also the PHPBB. from 2.022 to version 3 was a big step in development. now we are waiting for fintunning. keep going
  14. oneobserver
    Nov 12, 2007
    22
    Thank you for turning the search function back on. It appears to be working well now, and at least this way we have the other link if you have to turn it off again. I don't mind having to use the other site, just needed to know it was there...
    markh
