Searching recordings in V15
Discussion in '3CX Phone System - General' started by jofer, Aug 17, 2017.
  1. jofer
    Dec 5, 2012
    50
    Is there another way of searching entry's in the recordings?
    It looks like i can only search by number dialed to and from, but no filters like to select dates or any other filters.
    This makes it a nightmare for lookups.
    Regards
    Johan
  2. AndreasPo_3CX
    AndreasPo_3CX Support Team
    Aug 10, 2017
    138
    12
    Hi @jofer,
    you can search all the fields in the recordings, including the date or filename but you are right that you cannot filter the results in more detail. You can post it as a feature request on our ideas section of the forum though where it can be up-voted by other users and can be evaluated by the appropriate department
  3. jofer
    Dec 5, 2012
    50
    Thank you Andreas, I have added it.
    AndreasPo_3CX likes this.
