Second call issues
Discussion in '3CX Phone System - General' started by jgibbons3, Jan 23, 2017.
  1. jgibbons3
    May 17, 2016
    14
    I have 2 issues while on another call.
    1) Unable to see the caller ID of incoming call
    2) Unable to answer the second call from Yealink T41P
    We have v15 SP4 running and aceept mulltiple calls is enabled for all extensions.
    phones are Cisco SPA504G and Yealink T41P
    All incoming calls go to a ring group that all extensions belong to
    The Cisco Phones are able to answer a second call if BLF is set for another extension
    There must be a way to configure phones/routing so it is possible to see and answer an incoming call while on another.
    All help is Greatly appreciated!!!
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,398
    273
    I think the ring group is key here. I would check direct calls first (ext->ext) and check that is working.
    There is a custom parameter: ALLOWUSEBUSYOPTFORGROUP that should help with that. Recommend having a good backup before you make any changes in here.
  3. jgibbons3
    May 17, 2016
    14
    Thanks for the quick response -- That solved both issues changing default setting from 0 to 1
