Solved Second time in a year APN Certificate expired
Discussion in 'iOS' started by azarett, Oct 29, 2017.
  1. azarett
    Aug 24, 2012
    Shortly after installing v15, Apple PUSH notifications started to fail for a customers all-mobile support center. Wasted a lot of time and effort that morning trying to diagnose, and then quickly applying updates.
    Same thing yesterday, Certificate expired again.
    Im not into software dev, so I dont know what much about APN, but I know I can get an SSL cert good for years.
    Is there a 1 year limit from Apple on this ? Should I expect this to happen every year ?
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,476
    67
    Yes, Apple certificates - including the APNS - has one-year validity only (I don't know what the reason is) and we have to renew it accordingly, every one year. On PBX, customer side, we distribute the renewed one via a (silent) PBX update. We will check tomorrow about this and we'll keep you informed.
    Sorry for inconvenience.
    vali
  3. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
  4. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,283
    68
    Yes, the certificates that Apple issues have a 1 year validity, probably because the membership is also renewed annually. We usually try to release the updated/renewed certificate as a 3CX update at least 30 days prior to it expiring.
    We have explored this as an option quite a while ago. While it is not out of the question moving forward, the implementation of this is not as easy as it may sound as there are many things to consider, so for the time being it will stay as is with the certificate.
  5. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    But note that obviously some installs run as set it and forget it. So they will not timely upgrade(literally zero admin).
    Perhaps new method should be used only in standard edition as incentive to upgrade?
    I'm sure that one those things that probably .p8 file should not be accessed from disk. Instead after each restart PBX will remotely ask for contents of file which will be stored in variable. It will use same token if it is not over 1 hour old.
  6. Dymaxion
    Feb 4, 2016
    Hi is there any update where we can get the valid certificate? We are running on v14 still so I need to manually put the cert back in. We need this asap.
    Thanks.
    Lloyd
  7. Marios Neophytou
    Marios Neophytou Support Team
    Mar 1, 2016
    245
    12
    Unfortunately v14 is no longer supported. In order to have Push working you need to move to V15 or V15.5 as the new update for Push Cert is only for V15 and V15.5.
    Thank you
  8. Murat_Cakir
    Nov 3, 2017
    5
    Where can we find the v15 certificate ?
  9. Murat_Cakir
    Nov 3, 2017
    5
    Hello.
    The push services of our apple phones are not working. We need to do it ?
  10. Marios Neophytou
    Mar 1, 2016
    245
    12
    Just to make my self clear.
    3CXPhone system version 14 is not longer supported by 3CX - i.e. no latest updates in general.
    In order to have the latest updates you must update to V15 or V15.5 . If you need further instruction on how to do so, then please contact 3CX support.
    Thank you
  11. Murat_Cakir
    Nov 3, 2017
    5
    I solved the problem .Thanks
