Secondary proxy in UI
Discussion in 'Ideas' started by Jim Canfield, Jan 2, 2018.
Secondary proxy in UI 5 5 2votes
5/5, 2 votes
  1. Jim Canfield
    Nov 16, 2017
    13
    Would be great if the provisioning UI offered a second proxy address so you can simply add a second SBC and have local fail-over in the event the SBC is down or failed. I've tested this with custom templates and multiple SBC's and it works great. Just wish it was native in the UI.
    new29 likes this.
  2. new29
    Apr 12, 2012
    11
    I would like this as well. Mind sharing your custom template?
