secure sip problems
Discussion in '3CX Phone System - General' started by equintana, Jan 15, 2011.
  1. equintana
    Dec 20, 2010
    57
    I used the attached link to configure secure sip probing 3cx phone software. Without secure works and problems with secure sip.
    Cert and key configured as shown
    any idea?
    http://www.3cx.com/blog/voip-howto/secure-sip/
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Hi, Check the following -
    1. “root_cert_3CXPHONE.pem” rename again the file to “root_cert_3CXPHONE.crt”.
    Double click and check Valid From Date is correct.
    2. When you are trying to connect using tls with the 3cxphone, are you specifying the port 5061?
    Example: Local IP: 10.0.0.0:5061 i.e. ip address of the 3CX Phone System:5061
    See Screen-shot.
  3. equintana
    Dec 20, 2010
    57
    and...
    if I use iphone 4? possible? right now using without ssl
  4. equintana
    Dec 20, 2010
    57
    I did not use server:5061... only server.
    After insert cert file and use server:5061, the 3cx phone can not connect with the server
  5. equintana
    Dec 20, 2010
    57
    20:39:26.449 Got TLS read ret=0 error=6 error:00000006:lib(0):func(0):EVP lib
  6. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    I am sorry but if you read the post you can see that there is only 3cx phone for windows and eyebeam.
    We did not specify 3cx phone for iphone. Yes, you will have this, really soon!!!
    \\\"I did not use server:5061... only server.
    After insert cert file and use server:5061, the 3cx phone can not connect with the server"
    So then you have something wrong from your side I am 100% sure...
    From this message I cam understand - 20:39:26.449 Got TLS read ret=0 error=6 error:00000006:lib(0):func(0):EVP lib
  7. equintana
    Dec 20, 2010
    57
    HI,
    Then, for my iphone I´ll wait.
    But my 3cxphone, I used simle CA what could be wrong? cert? 3xcphone running under win 2008 server sp2
  8. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Hi, I would consider you to redo secure sip step by step again....
    It is not a matter of machine, you probably missed something.
  9. equintana
    Dec 20, 2010
    57
    I used the server´s ip instead the fqdn... now works!!!
