Secure SIP with TLS
Discussion in '3CX Phone System - General' started by computerstlouis, Aug 20, 2013.
  1. computerstlouis
    Aug 20, 2013
    Does anyone have an idea how much additional overhead enabling Secure SIP with TLS creates for the server's processing or additional latency in packets?
    Just curious to make sure I don't turn it on for a couple clients and kill their performance.
    Thanks,
    Seth
  2. bardissi
    bardissi Member
    Jan 31, 2012
    318
    The short answer is that TLS can compound the processing load from 3 to 17 times the normal processing requirements depending on environmental circumstances.
    Check out this doc which goes through a pretty deep analysis on this topic.
    http://www.cs.columbia.edu/~hgs/papers/Shen1008_TLS.pdf
