Security Issues
Discussion in '3CX Phone System - General' started by David Mactaggart, Jan 21, 2016.
  1. David Mactaggart
    Jun 19, 2015
    Can you let me know if there is any plans to increase the security of the system. Currently if you have access to a backup of 3CX you can gain the passwords used for everything. Are you planning on adding encryption to the backups or anything that would make this inaccessible without a password?
    Thanks,
    David
  2. Futureweb
    Futureweb New Member
    Jun 29, 2015
    163
    14
    I would suggest to use correct Folder Permissions - so noone can access Backup Folders except Users which are allowed to.
    Apart from the fact that only Persons which are allowed have access to the PBX should be able to log into that System.
    Andreas Schnederle-Wagner
  3. David Mactaggart
    Jun 19, 2015
    That is fine but you still shouldn't be able to access all passwords from an XML file in an unencrypted ZIP file
  4. leejor
    10,767
    286
    In the past, some users, having forgotten their password, (I know, I know), have had to resort to recovering it from the backup, so in those cases, it's a good thing that it wasn't encrypted.
    Personally, I think that asking 3CX to encrypt the backup file , is simply removing the responsibility from the users, to ensure security of their own system/files. You could submit a Feature Suggestion, of an option, to allow password protection of the zip file... http://www.3cx.com/forums/3cx-ideas-f57.html
  5. David Mactaggart
    Jun 19, 2015
    It's not about removing responsibility from the user but no decent program will store passwords in plain text anywhere, I will raise it on the ideas page though
