Solved See the sender of a transfer in phone display
Discussion in '3CX Phone System - General' started by JacobJ, Sep 22, 2017.
  1. JacobJ
    Sep 22, 2017
    12
    7
    we are using 3CX with Yealink T46G Phones and want to see the sender of transfered calls in phone display. As an example for an blind transfer:
    "external number via internal number"
    Is that possible?
    Regards,
    Jacob
  2. GiannosC_3CX
    GiannosC_3CX Guest
    Hi JacobJ,
    Unfortunately this is not possible at the current time as this feature does not exist on the PBX side.
    I would recommend to post a feature request on our Ideas section about this : https://www.3cx.com/community/forums/3cx-ideas/
  3. JacobJ
    Sep 22, 2017
    12
    7
