Segregating users on 3CX
Discussion in '3CX Phone System - General' started by Ralph, Aug 27, 2007.
  1. Ralph
    Ralph Member
    Jun 28, 2007
    417
    I've been talking with a client that owns 2 seperate small businesses.
    He would like to have both businesses run off the same PBX.
    Is there a way to segregate the 2 businesses on the same 3CX server so that the users are not able to call extentions in the other business?
    Thanks again
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    If they can not call each other -- What is the reason to run it on one 3cx server than?
  3. Ralph
    Ralph Member
    Jun 28, 2007
    417
    Good afternoon
    He wants to save on the cost of having a seperate server for each company.
  4. archie
    3CX Support
    Aug 18, 2006
    1,299
    We never thought about such scenario. And, presonally, I don't think it is worth of efforts. Actually, he don't need dedicated servers, especially for small business office, so it couldn't be the reason.
  5. daves
    Aug 26, 2007
    24
    Hi Ralph
    You asked - Is there a way to segregate the 2 businesses on the same 3CX server
    so that the users are not able to call extentions in the other business.
    Consider This for a theory - If for example the extensions in one business are say in the
    range 700 - 709 and the other business 710 - 720, then in the phones create different dial
    plans depending on which of the businesses the phones are from. Such that the dial rule for
    the 700 - 709 business phones would look something like this (70xS0|71x!) and the other
    business would have phones with the dial plans like (71xS0|70x!). This would mean that
    each of the two businesses can call the extensions in their own group of extensions,
    but be barred from calling extensions in the other business group. Of course it would
    depend on the phones being used if you can include the above concept in the dial plans.
    I hope this helps
  6. Ralph
    Ralph Member
    Jun 28, 2007
    417
    Thanks daves
    Thanks daves,
    I hadn't thought about trying to segregate them using the phones software. :)
    I'll look into it.
    Good morning Archie,
    I only know that he (the client) asked for this capability. Naturally, I have to see if it's possible in order to facilitate a sale.
    Take care,
  7. Psychlist1972
    Aug 20, 2007
    27
    Another option, if they want complete segregation and the ability to have different prompt sets etc, would be to have virtual servers running on the same physical hardware. Each virtual would have one business on it.
    You'd need to segregate any gateways too, I would think.
    I haven't tried this, but I assume it would work.
    Pete
  8. archie
    3CX Support
    Aug 18, 2006
    1,299
    Roger that it will work on virtual servers, but it may appear choppy if hardware is not powerful enough. And one needs quite good (nearly high end) box to run couple of virtual servers smoothly. Especially if a lot of IVR functionality involved (writting/reading v-mails is quite disk I/O consuming).
    I still think it's cheaper to buy two (even outdated PCs) - and they will work better.
  9. tjabaut
    tjabaut New Member
    Jul 24, 2007
    123
    Maybe someone has simply overlooked this but what about using different digital receptionists and utilize different inbound rules.
    If say 555-1234 rings then direct to IVR1 for XYZ Company
    or
    If 555-1235 rings then direct to IVR2 for THY Company
    You could setup your extensions any way that you want.
    This is the real flexibility that VoIP offers. The ability to think "outside the box"
  10. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,971
    280
    A multi tenant PBX is definitely an interesting option but not something that we will be doing very soon. We have our road map pretty much done for v4 and v5 which will take us into q1 of next year. But beyond that we might consider it...
