select external line
Discussion in '3CX Phone System - General' started by srg07, Jul 25, 2008.
  1. srg07
    Jul 25, 2008
    How can I select external line when maiking a call ?
    In classic pbx I use for example 9(any by pbx), or desiered extention (710...715) then number XXXXXXXXX
    But in 3cx using SJphone I could'n specify ext line.
  2. srg07
    Jul 25, 2008
    I see
    but is it the only way defining out rules for chosing ext line ?
    Fo example I have extention 100-104 and VOIP provider's lines as 10000 and 100001/
    What mean these numbers ?
    In classic pbx I would use these numbers to directly specify ext line - 10000 then XXXXXXXXX....
  3. Anonymous
    Anonymous Guest
    This is not necessarily the case in the PBX.
    In terms of the gateway, lines are numbered as you are explaining. However, 3CX treats the numbers offered as a pool, and will route calls to the pool. Which number the call actually goes out on is not determined.
  4. srg07
    Jul 25, 2008
    What algoritm is used when chosing ext lines ?
    I noticed that the first line always chosen first not round robbin...
  5. tazz
    tazz New Member
    Sep 12, 2007
    124
    If i make it my second line, then the first is captured & the call will not go out
