Select outbound route
Discussion in '3CX Phone System - General' started by comnetcon, Jun 10, 2014.
  1. comnetcon
    Jul 20, 2011
    7
    Hello all,
    Version 12 SP5. Grandstream 4108, 7 analog lines. Phones - Yealink T32G
    I need to setup outbound rules so that by dialing a specific prefix I can force the outgoing call through a specific line.
    In the Outbound Rules setup my only option in the routes is to select the Gateway itself or BLOCK CALLS.
    How can I force the call out a specific phone line?
    David
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,407
    274
    The 4108 would need a method to separate the lines and have separate registrations to 3cx.
    I would post this on the Grandstream site for better visibility.
    Or read this: http://www.grandstream.com/products/gxw_series/gxw410x/documents/gxw410x_interop_3cx.pdf
    Looks like this device can have multiple profiles...with separate channels setup.
  3. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    You can use Dinstar DAG1000-8O instead, it has much better functionality than GXW4108 like trunk groups, routing, etc. More info available at: http://www.dinstar.com/Product/Product_23.aspx?typeid=11
    We sell it in Europe at: http://sip.bg/voip-gateways/analog-gateway/DAG1000-8O
  4. eagle2
    Apr 27, 2011
    1,085
    11
