Selecting GSM codec.
Discussion in '3CX Phone System - General' started by xray, Aug 25, 2009.
  1. xray
    Mar 21, 2009
    Greetings,
    I was wondering if anyone has run into any issues trying to select the GSM codec when communication from a VOIP client to a 3CX server system? Or better stated, does anyone know how to make this work?
    We have our own VOIP client communicating with 3CX and offer GSM (highest priority), PCMU, PCMA (lowest), but the 3CX system does not select the GSM codec. If we force the selection to GSM by only offering the GSM codec (no others), we establish a call to the 3CX system (calling voice mail, etc.) with the GSM codec chosen, but we get no audio from the 3CX side.
    Is there some configuration step/magic that we're missing to make this work?
    Thanks in advance.
    11,291
    361
    GSM codec won't work in the "Free" version unless you use the Demo licence and restrict 3CX to two simultaneous calls. At least, that's the way I understand it, anyone else?
