self identification message via Admin
Discussion in '3CX Phone System - General' started by LiveRock, Jan 21, 2015.
  1. LiveRock
    Jan 19, 2015
    17
    Is it possible to use a pre-recorded wave file as self identification message for each extension by manually set it using the SERVER MANAGER interface?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,134
    211
    If you name the file with the same naming format you should be fine...
    Go to the voicemail tab and hit ADD.
    (Have not tried.)
    Ps - ensure file is proper format according to the manual.
