Send call to an endpoint directly (not register)
xc99tour
I would like to define an extension that I can send calls to without having to register it. I.E. 3CX would just send an invite to [email protected] without having to first register the extension. Is that possible?
Thanks,
Larry
Currently, it's not possible, because there's no way to speify IP of extension from web-interface. It could be acquired only by registration.
Register a trusted source
I have an endpoint that can register but is not capable of authincation. Is there any way to accept a registration without requiring authincation?
Thanks,
Larry
Re: Register a trusted source
Thanks,
Larry
Yes. Just make blank Password field in Authentication section of Edit extension screen.
No luck
I thought of that and tried it again after reading your suggestion. Did not work. When I set up the ext. I did it with out an auth name and password. Then tried putting the ext. number in the name, blanking out the password. did not work either.
What can I send you do document this?
Larry
Frame 38 (425 bytes on wire, 425 bytes captured)
Ethernet II, Src: DellPcba_2b:6f:99 (00:0d:56:2b:6f:99), Dst: DellComp_0b:d0:25 (00:08:74:0b:d0:25)
Internet Protocol, Src: 192.168.0.5 (192.168.0.5), Dst: 192.168.0.3 (192.168.0.3)
User Datagram Protocol, Src Port: 5060 (5060), Dst Port: 5060 (5060)
Session Initiation Protocol
Request-Line: REGISTER sip:192.168.0.3 SIP/2.0
Method: REGISTER
[Resent Packet: False]
Message Header
From: <sip:[email protected]:5060>;tag=ds-67f5-254f5617
SIP from address: sip:[email protected]:5060
SIP tag: ds-67f5-254f5617
To: <sip:[email protected]:5060>
SIP to address: sip:[email protected]:5060
Call-ID: b35c1ce7-afce-11db-a5e7-ad26eb022f44@voip
CSeq: 337 REGISTER
Content-Length: 0
Expires: 3600
Contact: <sip:[email protected]:5060>;expires=3600
Contact Binding: <sip:[email protected]:5060>;expires=3600
URI: <sip:[email protected]:5060>
Via: SIP/2.0/UDP 192.168.0.5:5060;branch=z9hG4bKb35c1ce9-afce-11db-9bd2-87b9f7103cec
Transport: UDP
Sent-by Address: 192.168.0.5
Sent-by port: 5060
Branch: z9hG4bKb35c1ce9-afce-11db-9bd2-87b9f7103cec
Max-Forwards: 70
No. Time Source Destination Protocol Info
39 8.815899 192.168.0.3 204.174.223.59 POP Request: USER crossroadscy05
Frame 39 (75 bytes on wire, 75 bytes captured)
Ethernet II, Src: DellComp_0b:d0:25 (00:08:74:0b:d0:25), Dst: Symantec_b5:9c:96 (00:a0:65:b5:9c:96)
Internet Protocol, Src: 192.168.0.3 (192.168.0.3), Dst: 204.174.223.59 (204.174.223.59)
Transmission Control Protocol, Src Port: 4861 (4861), Dst Port: pop3 (110), Seq: 1, Ack: 48, Len: 21
Post Office Protocol
40 8.903494 192.168.0.3 192.168.0.5 SIP Status: 407 Proxy Authentication Required (0 bindings)
Frame 40 (510 bytes on wire, 510 bytes captured)
Ethernet II, Src: DellComp_0b:d0:25 (00:08:74:0b:d0:25), Dst: DellPcba_2b:6f:99 (00:0d:56:2b:6f:99)
Internet Protocol, Src: 192.168.0.3 (192.168.0.3), Dst: 192.168.0.5 (192.168.0.5)
Status-Line: SIP/2.0 407 Proxy Authentication Required
Status-Code: 407
Get 3CX - Absolutely Free!
3CX
