send caller ID in mail
Discussion in 'CRM / Helpdesk / App Integration' started by Nick@Troosters, Sep 18, 2014.
  1. Nick@Troosters
    Nov 12, 2012
    22
    I want to create a workflow where a client can choose to login (press 1) or logout (pressing 2) , then enter her PINcode and then a mail is send to person X with the PINcode , login or out and the caller ID (or even the company linked to that caller ID) in the mail message.
    Is this possible with VAD, or what is possible ?
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Hi Nick,
    Yes, it's perfectly doable with the VAD.
    To do it:
    - First you can use a menu component to select 1 or 2.
    - Then a user input component to enter the PIN.
    - Then use an Email Sender component to send the message.
    - You may use a Database Access component to lookup the customer name based on the caller ID for example.
    If you have any other question do not hesitate to contact me again.
    Kind regards.
  3. pierre13
    Aug 27, 2015
    hi i have send pin and sender e mail
    how does it to retrieve the user id to send in an email?
  4. VAD_Support
    Aug 6, 2009
    690
    The caller ID is available thru the session.ani variable. You can use that variable to the get the actual value, and insert it in any expression in your callflow, for example the mail body or the mail subject.
  5. pierre13
    Aug 27, 2015
    I do not understand at all
  6. VAD_Support
    Aug 6, 2009
    690
    This article explains exactly that:
    http://www.3cx.com/blog/docs/emails-from-vad/
    The email subject contains the caller ID.
