Send CallerNumber to Script
Discussion in 'Call Flow Designer' started by MCSH, May 16, 2018.
  1. MCSH
    May 9, 2018
    8
    me again :-/.
    I will do following:
    I will read the callerNumber ex.: +49211111111 or +12232323
    I will search in a c# if number begins with "+49" then it will return a value to know its german language else it will be in english.
    I tested to send parameters to my script, but I didn't know how to get the original callerID:
    This is the only option to include some values to find out the origin phone number, but there is no default var, to send as parameter:
    [​IMG]
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    997
    73
    You're using the Call ID and not the Caller ID. The caller number is available in the session.ani variable.
    Kind regards.
  3. MCSH
    May 9, 2018
    8
    Hi Edossantos,
    thanks for your Reply, but this number variable Shows the DDI the Queue is connected to:
    session.ani: the number of the caller connected to a CFD app.
    It isn't the number of the callee. I checked and I see only the number which is configured to the Queue there the CFD app is connected to
  4. edossantos
    Jun 27, 2007
    997
    73
  5. MCSH
    May 9, 2018
    8
    I have seen the vars, but the result off session.ani is another. It will be shown the DDI of the called Queue not from the origin phone
  6. edossantos
    Jun 27, 2007
    997
    73
    Are you transfering the call from a queue to this CFD app? Can you describe the flow of the call since it arrives to 3CX? The variable session.ani should have the caller number, but if your CFD app is receiving the call from a supervised transfer, then you will see the extension number of the person transfering you the call...
  7. MCSH
    May 9, 2018
    8
    Hi edossantos,
    I checked again, I'm really sorry, you are total right.
    I checked the wrong longfile I have created.
    The original callernumer will be shown with session.ani.
    Sorry :(
