Send calls to extenstion based on area code on CLI
Discussion in '3CX Phone System - General' started by garethb_83, Feb 14, 2011.
  1. garethb_83
    Oct 11, 2007
    25
    Is it possible to create incoming rules which would look at incoming CLI and route to extension ring group based on that being defined..
    I thought this was available from memory but now actually trying to find that feature I cant find it. Could have been dreaming tho..
    Thanks.
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Dummy extennsions are your friend, you can send the incoming call to a dummy extensions and in the exceptions tab of the forwarding rules enter the CLI that you want to forward use a star at the beggining *. THen simply route it to where you want to go. THere is a limit of 15 you can add here, if you need more keep on creating dummy extension as it goes further along.
