Send Email notification if scheduled backup fails IN CONSIDERATION
Discussion in 'Ideas' started by akacomp, Sep 30, 2015.
  1. akacomp
    Dec 13, 2011
    Now that we have scheduled backups , it is very important to add email notification if a scheduled backup fails.
  2. AlexHeylin
    Nov 30, 2015
    44
    9
    Suggestion - implement this outside of 3CX. Reason - if 3CX doesn't complete the backup OK, it might not send the email either. So either email on all backups stating result (then missing email = problem) or check from outside 3CX via some other means so you're not relying on a failing system to tell you it's failing (which is just a problematic idea).
