send fax via ATA fax
Discussion in '3CX Phone System - General' started by druid33, Mar 31, 2010.
  1. druid33
    Mar 26, 2010
    i have Linksys SPA 3102 , ATA fax 3cx Phone system 8 free edition. I have configured Linksys to send Fax with manual on this sites(http: //www.3cx.com/sip-phones/linksys-spa-3102-fax/ No longer available. New link: http://www.3cx.com/sip-phones/). I can receive faxes, i can call from outside phone to fax machine, i can call from/to internal phone to/from fax machine, but i can`t send fax or call from fax machine to outside. Fax machine generate comunication error.
    log from 3cx:
    Kindly remember to place code and /code tags for server logs- MFM
    Code:
    17:01:36.218  [CM503008]: Call(4): Call is terminated
    17:01:35.375  [CM503007]: Call(4): Device joined: sip:10000@10.0.1.48:5062
    17:01:35.359  [CM503007]: Call(4): Device joined: sip:30@10.0.1.48:5060
    17:01:35.359  [CM505002]: Gateway:[PSTN Gateway via Linksys 10.0.1.48] Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3102-5.1.10(GW)] PBX contact: [sip:10000@10.0.1.10:5060]
    17:01:35.359  [CM503002]: Call(4): Alerting sip:10000@10.0.1.48:5062
    17:01:35.312  [CM503025]: Call(4): Calling PSTNline:0911146656@(Ln.10000@PSTN Gateway via Linksys 10.0.1.48)@[Dev:sip:10000@10.0.1.48:5062]
    17:01:35.250  [CM503004]: Call(4): Route 1: PSTNline:0911146656@(Ln.10000@PSTN Gateway via Linksys 10.0.1.48)@[Dev:sip:10000@10.0.1.48:5062]
    17:01:35.250  [CM503010]: Making route(s) to <sip:00911146656@10.0.1.10>
    17:01:35.250  [CM505001]: Ext.30: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3102-5.1.10(GW)] PBX contact: [sip:30@10.0.1.10:5060]
    17:01:35.250  [CM503001]: Call(4): Incoming call from Ext.30 to <sip:xxxxxxxxxxx@10.0.1.10>
    xxxxxxxxxxxxx- its some external number
    Any ideas whats wrong?
    thanks for reply
    11,079
    324
    Fax over VoIP is tricky. See...http://www.soft-switch.org/foip.html It can all come down to the make/model of your fax machine.
