Send Notification when do a phone call
Discussion in '3CX Phone System - General' started by johann_wnd, Sep 11, 2015.
  1. johann_wnd
    Sep 11, 2015
    Hello everybody
    is it possible to receive an email, when some extension do a phone call.
    we use a hotel model without a pms.
    now it will be good, when the reception get an email when one of the guest do a phone call.
    so the reception do not forget to put the costs of the phone calls on the bill.
    Best regards
  2. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    862
    130
    Can you not use Hotel addin without PMS function
    Look at the manual may help you, not sure if reporting function available
    http://www.3cx.com/docs/hotel-manual/
  3. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    I believe that the hotel module, upon guest checkout, provides a notice as to whether the extension has any call with toll fees. From there, the desk personnel can then print out those calls with their associated costs for inclusion into the guest bill.
    As far as I know, there is no feature that causes real-time print out of calls. There may be a call accounting package that can take the CDR output and do this or you might contact Voip Toys (http://www.voiptoys.com/) as they may be able to develop a solution for your needs,
