Send Text message using 3CX API
Discussion in '3CX Phone System - General' started by pat71, Apr 14, 2016.
  1. pat71
    Mar 17, 2016
    44
    Hi every one,
    Can we send text message using 3CX API? is it possible.
    11,079
    324
    A text message to what? A 3CX Phone, a mobile phone?
  3. pat71
    Mar 17, 2016
    44
    TO mobile phone
  4. leejor
    11,079
    324
    You would require a paid subscription to a SMS gateway to begin with. I haven't seen anything (myself) to interface to one.
  5. pat71
    Mar 17, 2016
    44
    I do have registration, but i do not know how to do that using API. But there is other way but I need to know how to assign wav greeting file to certain extension using 3CX API.
    Do you know how to use API to set the greeting for certain extension? I know that it might be done by setting it in the extension profile but do not know how.
    Hope you can help me on this.
  6. leejor
    11,079
    324
    Not having been involved with API, I'm afraid I wouldn't be of any help with the actual application. Someone else, however, may. I haven't seen text messaging (to a mobile) come up in the forum, as a viable option at this point. As I said, any outside text options (sending to a mobile) would still require a (paid) subscription to an outside SMS gateway service.
  7. pat71
    Mar 17, 2016
    44
    Thank you for your reply.
  8. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    64
    Take a look at the following as it may be of use in your efforts. There are some links that provide additional info.
  9. pat71
    Mar 17, 2016
    44
    were should I look, i think you missed putting the link for me.
  10. lneblett
    Sep 7, 2010
    2,086
    64
