Send to Multiple email addresses
Discussion in '3CX Phone System - General' started by kraichle, May 23, 2016.
  1. kraichle
    May 23, 2016
    39
    I'm assuming the answer is no since I couldn't find anything instructing how to do it, but is there a way to add more than one email address to an extension?
    justaguy likes this.
  2. 3CXusername
    3CXusername New Member
    Jul 31, 2014
    182
    15
    tried with comma, space, and semi-colon so doesn't appear to access more than one.
    I would set up a distribution group on MTA if you needed to notify multiple members.
  3. uptime1
    uptime1 New Member
    Jan 13, 2012
    112
    31
    +1
    OP, pls submit as an Idea and post on this thread the url so others can Upvote your great idea!
  4. justaguy
    Mar 22, 2017
    What is MTA?
  5. dab
    dab
    Nov 1, 2009
    67
    MTA = Message Transfer Agent = your Mailserver
  6. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,335
    222
    The only way currently, create a distribution group on your email server and send to this
