Send voice message
Discussion in '3CX Phone System - General' started by spring, Oct 20, 2016.
  1. spring
    Nov 20, 2014
    53
    Could anyone tell me how to send voice message from 3CX?
    Which is the best application to integrate to run this features?
    Regards,
    Spring
  2. Anonymous
    Anonymous Guest
    Could you explain what you mean with more detail? It obvious how to leave voicemail for an extension so I'm sure thats not what your asking. Also fowarding email to an email address is fairly simple. If you provide more detail, I'm sure the answer will be easy to provide.
  3. spring
    Nov 20, 2014
    53
    Hi Helia,
    Thanks for your comment here. i want to record voice ( like promotion program) and send call to multiple customers by their mobile number. Any idea?
  4. Anonymous
    Anonymous Guest
    Yes. It's not available from 3cx. There are two options. Hire someone to write a program and connect to the 3cx API or use Acarda. Acarda comes from a company in new Zealand and is compatible with 3cx
  5. spring
    Nov 20, 2014
    53
    Hi helia,
    Ok thanks you so much for your advise.
