Send Voicemail as Email Attachment
Discussion in '3CX Phone System - General' started by LCC, Aug 21, 2015.
  1. LCC
    LCC
    Jul 8, 2011
    42
    I just did the upgrade from 12 to 14. I did go to 12.5 first. Everything is working except i am not receiving voicemails via email attachments. I do have a paid license. THe only thing that changed is I do not have a FQDN and it forced me to install on Abyss. That is the only change. Has anyone else experienced this?
    11,277
    360
    Did you confirm that the option, in one of the extensions affected, is still set for this? I can't see why it would change....but
  3. LCC
    LCC
    Jul 8, 2011
    42
    I did confirm. And it is a global issue. All previous extensions that had been working are now not working, and the options are all checked for these options.
  4. leejor
    11,277
    360
    Are any emails being sent? What if you were to change an extension to only send notification of a message.
    I'm just wondering if something has changed that has affected 3CXs ability to send.
  5. LCC
    LCC
    Jul 8, 2011
    42
    Good thought. I tried and notifications aren't going out either. The email box is working. I can manually log in and send and receive emails. I am at a loss.
  6. leejor
    11,277
    360
    I realize that this post is dealing with much older versions, but, the third entry mention a log to check. That file/directory may be re-named in version 14 but shouldn't be too difficult to find. It might help with determining what is causing the issue.
    http://www.3cx.com/forums/voicemail-to-email-does-not-work-18229.html
    You might also try taking out, then putting back all settings related to email. There may have been some corruption introduced in the transfer process.
    Another thought...could it have anything to do with the licence? Do you have any sets that use a "standard" Message Waiting Indicator (lamp)? Does that work? Normally, in the "free" or unlicensed version, it won't.
  7. tsukraw
    tsukraw New Member
    Mar 9, 2012
    191
    9
    Do you know how to do a wireshark capture?
    If you could install wireshark and run a capture when trying to send a welcome email.
    That we we could see if there is some SMTP communication issue going on.
    If you could either PM me or attach the capture to the post.
  8. 12494
    12494 Member
    Apr 16, 2010
    311
    31
    Have you verified the smtp mail server settings?
    Can you successfully send the Welcome Email?
    Allen
  9. LCC
    LCC
    Jul 8, 2011
    42
    MWI works fine. Good thought. Thanks. I have the licenesed, paid version. It's a PBX in my house so the complexity is minimal. And this was working fine BEFORE the upgrade. So frustrating.
  10. LCC
    LCC
    Jul 8, 2011
    42
    I'll do that as soon as I get a free moment. So frustrating this was working fine until the upgrade.
  11. LCC
    LCC
    Jul 8, 2011
    42
    Nothing has changed since the upgrade, and I did re-enter all valid SMTP settings and credentials.
  12. 12494
    12494 Member
    Apr 16, 2010
    311
    31
    And I repeat -
    Allen
  13. LCC
    LCC
    Jul 8, 2011
    42
    I get an exception error. unable to connect to the remote server. Very interesting. BUt that gave me a thought. My internet provider blocks port 25. I added designation to communicate on port 80 to my smtp settings and that did it! Thanks all! Not sure why that setting did not ome over when I restored. I am getting old...
  14. leejor
    11,277
    360
    So..... was the port set to 25, or 80 in the old installation? If it had been set to 80, does that mean that 3CX did not correctly pass on the "correct" setting from the back-ups? Or, did you change providers while all of this was going on?
    It would be a bit of a concern, if the setting had managed to change itself between installations.
  15. LCC
    LCC
    Jul 8, 2011
    42
    it was set to port 80 for years. Had this problem years ago and had done that. I used a backup from right before I started the upgrade and assumed all settings were carried over, so I never even thought that might be the issue. The port 80 setting did not carry over.
