Sending a fax through 3CX
Discussion in '3CX Phone System - General' started by MagicRatFish, Sep 5, 2013.
  1. MagicRatFish
    Aug 11, 2013
    I am trying to send a fax through the 3CX server but am not finding any documentation on how to do it. The manual talks about sending/receiving faxes, but then only documents receiving them. Can I Use the Microsoft Fax client? 3CX used to have a fax sending module, but no more? What replaced it? Do I need a third party solution?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,587
    309
    I do not know of any send fax solution within 3cx without using a Fax Machine with an Analog Adapter.
  3. rogueblackburn
    Aug 11, 2013
    42
    Or a 3rd party fax server solution. 3CX Faxserver is receiving only. There are several solutions allowing you to integrate a fax server with the 3CX PhoneSystem using an "xcapi".
