Sending a fax thru the 3cx
Discussion in '3CX Phone System - General' started by giovanni0826, Apr 14, 2008.
  1. giovanni0826
    Apr 6, 2007
    53
    i have a ht-502 device with one of the phonelines connected to my fax machine. i can't seem to send a fax through the 3cx. any one offer assistance?
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Just to share with you.
    The following setting can send/receive T.38 FAX.
    - That extension in need to disable PBX Delivers Audio
    T1/PRI <----->PATTON SN4960<----->3CXBOX<-------->PATTON SN4114(FXS PORT)<------->FAX machine
    (It should be prefect match if all device are Patton)
    and
    T1/PRI <----->PATTON SN4960<----->3CXBOX<-------->HT503(FXS PORT)<------->FAX machine
    - Works at FW 1.0.0.5
    - All FAX calls will drop if FW 1.0.0.9.
    Since I haven't HT502. Therefore, I cannot tell you it works or not.
  3. giovanni0826
    Apr 6, 2007
    53
    thanks for your reply. but i'm using the patton device. i have it set as the following...
    VoiP Provider ---> 3cx ---> ht-502 ---> Fax machine (the FXS port is set for pass-thru). i can't get it to function. but when i take the 3cx out of line it receives just fine.
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Please try to disable PBX Delivers Audio at both extension setting for HT502 and Provider setting under "other options".
