Sending Fax Via 3CX Server
Discussion in '3CX Phone System - General' started by galal202, Jun 30, 2010.
  1. galal202
    galal202 New Member
    Jun 23, 2008
    235
    How Can I send a fax from pc via 3CX server?
  2. carolinainnovative
    May 4, 2009
    369
    6
    One way:
    1. Setup windows faxing on a server-type computer - or your pbx box - or some other place from which you can SHARE a device
    2. Install the 3cx fax driver on that machine. point it at your pbx
    3. Configure windows faxing appropriately - share the fax
    4. Connect to the fax from your workstation
    5. Print to the fax like any other printer
    6. hope it works...
    Another way (that i've actually gotten working):
    1. Create a new fax extension - lets say, 889. Create a password and remember what it is...
    2. Create an outbound rule for step 1's extension - send it to your T38 fax device - be that a specific voip provider, gateway box, or what not.
    3. Setup windows faxing on a server-type computer - or your pbx box - or some other place from which you can SHARE a device
    4. Download a trial of T38FaxVoip's T38 Fax Driver (http://www.t38faxvoip.com/download.htm)
    5. Install on fax server
    6. Configure with sip creds created in step 1
    7. Configure windows faxing appropriately - share the fax
    8. Connect to the fax from your workstation
    9. Print to the fax like any other printer
    10. hope it works...
    Unfortunately, "hope it works" is part of both of them. People have had success with both methods. I've NOT had success with the former - only the latter. The only catch for the latter - it costs $$ when you actually BUY said T38Fax Voip's driver.
    One VERY good thing to have installed while doing this - WIRESHARK.
  3. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Thank You for help
    I wonder in first way
    How Can I install 3CX Fax driver?
    and I think in second way you depend on voip provider
    I need to use pstn gateway
    Thank You
  4. carolinainnovative
    May 4, 2009
    369
    6
    Neither depend on a voip provider - both depend on using T38 to whatever endpoint you have - be it a voip provider or media gateway like a Patton or what not. Your gateway just has to support T38.
    To install the 3cx driver, basically download it and install it. in your management console, click "Link" then "Outbound Fax Server." It will ask you for the PBX ip address on install.
    If it doesn't work for you - you're gonna have to seek help elsewhere (ie with someone else on this forum) - I have yet to get it to work - hence why I used the T38FaxVoip... which works WONDERFULLY with 3cx.
  5. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    667
    7
    I have tested 3CX Fax server with Grandstream 4104. Works perfectly.
  6. galal202
    galal202 New Member
    Jun 23, 2008
    235
    When I tried to send the fax I got this message
    "Fax server information cannot be retieved
    The Fax wizard will close now."
    Any ideas
  7. igor.snezhko
    Jan 7, 2008
    667
    7
    Try to configure it according to manual
    http://www.3cx.ru/blog/how-do-i-install-microsoft-fax-services-on-windows-server-2003/
    http://www.3cx.ru/blog/how-do-i-install-microsoft-fax-services-on-windows-server-2008/
    I had not received any errors :roll:
  8. Melvin_XIII
    Oct 25, 2016
    35
    I realise this post is quite old by now. I was wondering whether one of the two methods described still work. The first I don't think will work as the sending function has been removed out of the fax service in 3CX. The second option I don't know whether or not it function.
    I am finding very little information concerning the sending and receiving of Fax. Any up to date info would be much appreciated.
