Sending FAX with 3CX V10
Discussion in '3CX Phone System - General' started by ulises, Aug 5, 2011.
  1. ulises
    Aug 31, 2010
    7
    Is there a way to send faxes directly from the computer using the 3CX v10 and an analog line or FXO?
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    3CX does not support sending Faxes. Search the blog http://www.3cx.com/blog and there you will find some options
    for sending faxes.
    Thanks,
    Nate
