- Joined
- May 26, 2010
- Messages
- 25
- Reaction score
- 0
I have been trying to send faxes using Microsoft fax, on the local machine, with faxback. I have managed to get it to register as an extension but 3CX throws an error, when an attempt is made to send a fax.
In the case below, faxback has registered as extension 14 from 192.168.1.15 and calling number 888888(obscured for privacy). Server is 192.168.1.11
I do not understand why contact is sip:[email protected] when registered as 14 in faxback.
Can anyone offer any advice?
Code:
23:49:21.298 [CM102001]: Authentication failed for SipReq: INVITE [email protected] tid=1005 cseq=INVITE [email protected]:5060 / 2 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
23:49:21.298 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
INVITE sip:[email protected] SIP/2.0
Via: SIP/2.0/UDP 192.168.1.15:5060;branch=z9hG4bK1005
Max-Forwards: 70
Contact: <sip:[email protected]:5060>
To: <sip:[email protected]>
From: "IPFax"<sip:[email protected]>;tag=IPF_PORT_0001_1003
Call-ID: [email protected]
CSeq: 2 INVITE
Allow: INVITE, ACK, BYE, CANCEL, REFER, NOTIFY
Proxy-Authorization: Digest username="14",realm="3CXPhoneSystem",nonce="414d535c0233207159:023e9954be61a3a7236da6385b1ec524",opaque="",uri="sip:[email protected]",response="5edc8d429f2bbc2f8b353fd533f6090f"
User-Agent: Net Satisfaxtion/IP_FAX-0.0.0.0
Content-Length: 0
23:49:21.298 [CM302002]: Authentication failed due to unidentified source of: SipReq: INVITE [email protected] tid=1005 cseq=INVITE [email protected]:5060 / 2 from(wire)
23:49:21.048 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
Via: SIP/2.0/UDP 192.168.1.15:5060;branch=z9hG4bK1004
Max-Forwards: 70
CSeq: 1 INVITE
Content-Length: 0
23:49:21.048 [CM302001]: Authorization system can not identify source of: SipReq: INVITE [email protected] tid=1004 cseq=INVITE [email protected]:5060 / 1 from(wire)
23:49:07.642 Active calls counted toward license limit: []
23:48:35.642 Active calls counted toward license limit: []
23:48:03.642 Active calls counted toward license limit: []
23:47:55.579 [CM504001]: Ext.14: new contact is registered. Contact(s): [sip:[email protected]:5060/14,sip:[email protected]:5060/14,sip:[email protected]:5060/14]
23:47:31.642 Active calls counted toward license limit: []
