Sending incoming calls with no caller ID to Voice-mail
Discussion in '3CX Phone System - General' started by DaveIW, Sep 22, 2007.
  1. DaveIW
    Sep 17, 2007
    19
    Is there any way to send incoming calls from an outside line direct to an extension's voice-mail if the incoming call has no caller ID?
    i.e. I dont want to talk to some one if they wont tell me who they are.
    I have done a search on here for "Inbound Rules" but didn't find anything, and I cant see an option on 3cx.
    Cheers for any help
    Dave
  2. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    No option on 3cx but u can do it
    Check this
    http://www.3cx.com/forums/categories-1/feature-requests-5/call-roughting-based-on-incoming-phone-number-2086/
    to forward to a voicemail just create a dummy extension going directly to Voicemail and use that extension with the "trick" on that post above
  3. DaveIW
    Sep 17, 2007
    19
    Cheers for that - much appreciated :)
    Dave
