Sennheiser 3CXPhone plugin for windows
Discussion in '3CX Phone System - General' started by jasonhayes, Mar 8, 2018.
  1. jasonhayes
    jasonhayes New Member
    May 9, 2012
    140
    9
    We purchased the DW10 Sennheiser headsets for the 3CXPhone. According the Sennheiser web site "The Sennheiser 3CXPhone plugin for windows is a call control integration module, which manages the connection between the Sennheiser headsets and the speakerphone solutions and the 3CXPhone client v15 or higher. With the Sennheiser 3CXPhone plugin, you benefit from a fully tested solution making use of 3CXPhone together with the Sennheiser devices. The answer and end calls functionality as well as volume functions, can be exercised via the headset or speakerphone."
    We can not get the answer button to answer a call via the 3CXPhone and headset. What I'm I missing...
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,480
    67
    Be aware, the 3CX client should NOT be in CTI mode.
